Novi veliki Strom (DL1000) 2012 - još jedan "avanturist"
moover
4,264
0
36
44
ZG
Danas svaki proizvođač gura naziv Advendure u modele, ne bi li ga lakše uvalio kupcu...
Konkurenciju ne vidi u Crosstoureru, Varaderu, velikom Versisu, nego u GS-u, Stelviu i ST-u...  :?
http://www.ultimatemotorcycling.com/2012-suzuki-v-strom-1000-adventure-preview
Ukratko...
2012 Suzuki V-Strom 1000 Specs:
Bore Stroke: 98.0 mm (3.858 in) x 66.0 mm (2.598 in)
Compression Ratio: 11.3 : 1
Engine: 996 cc (60.8 cu. In), 4-stroke, liquid-cooled, DOHC, 90-degree V-twin 9
Fuel System: Fuel injection
Ignition: Electronic ignition (Transistorized)
Lubrication: Wet sump
Starter:Electric
Brakes Front: Disc brake, twin
Brakes Rear: Disc brake
Curb Weight: 238 kg (525 lbs) (Adventure, TBD)
Final Drive: RK525 SMOZ7, 112 link
Fuel Tank Capacity: 22 L (5.8/4.8 US/Imp gal)
Ground Clearance: 165 mm (6.5 in)
Overall Length: 2295 mm (90.4 in)
Overall Width: 910 mm (35.8 in) (Advenutre, TBD)
Seat Height: 840 mm (33.1 in)
Suspension Front: Telescopic, coil spring, oil damped
Suspension Rear: Link type, coil spring, oil damped
Tires Front : 110/80 R19 M/C 59H, tubeless
Tires Rear: 150/70 R17 M/C 69H, tubeless
Transmission: 6-speed constant mesh
Wheelbase: 1535 mm (60.4 in)
Warranty:12 month unlimited mileage limited warranty.
Cijena Adventura (tamo negdje na drugom kraju svijeta) - cca 11.000 USD
kalimero
1,762
1
36
106
Tu i tamo
To je isti stari strom, samo za američko tržište, tamo ne trebaju euro norme.
Čeka se novi redizajnirani veliki strom sa značajnim preinakama, nešto kao i kod dl650, navodno se treba pojaviti 2013.
Kvoc
1,871
2
36
67
Malinska riva
:D veliki V2 je odlcan agregat  (y) Pitanje je samo usta je upakovan i dali se to potencijalnom kupcu svidja  :wink:
