Yamaha T-Max 530 - General Topic
Samo debil moze kupit ovu u odnosu na normlani. A za St je normalni t max iako debili kupuju tech max. 99% ne izade iz grada i kupuju ovog sta ima paz ‘ ovo: grijanje rucki i guzice( jos nekako), tempomat na skuteru( ajme meni majko) i aj dize se vizir( jedino ok)
Za one koji ne znaju. Nema socijalnog vise. Sad je samo sx( danas obicni) i tehmax( dx). :p
Šuška se da izlaze tri verzije tmaxa
THE TRINITY WITH A FEW MORE HORSES​
The three-wheeler should be called 3MAX , in order to declare a continuity with the sporty styles of the range. It would be the "brother" of the Tricity, but with more power , since it could mount the 2-cylinder 560cc with 48 hp , double compared to the 300cc of the Tricity.
THE RIVAL OF HONDA X-ADV​
The off-road TMAX would be powered by the same 560cc engine, but would perhaps be called the TMAX Adventure . In practice, it would be the declared market rival of Honda's X-ADV .
THE ELECTRIC TMAX WITH LONG AUTONOMY​
The hybrid version will not actually be ... hybrid. Or better: Yamaha is in fact developing a TMAX equipped with an Extended Range engine (EREV) , therefore an electric propulsion obviously powered by the classic battery pack ; however, the latter is powered by the energy generated by the heat engine . This solution allows the engine (hence "Extended Range") to boast greater autonomy .
Debili? A oni koji putuju pa kupuju bazni Tmax, smrzne im se dupe i ruke? I propusu klempave usi? Jel su i oni debili? Ponekd kad citam "argumente" ispadne kao da neki klinci pisu...
Putuju?:mrgreen:...ovi po Splitu ne putuju s tin motorima to je sve relacija Solin,Split eventualno Kastela a ljeti Duce...
Grijesis jako…..Duce su OK ali……
Ide se u Trogir i na Ciovo……polotirat po Saldunu…..neprocjenivo…….a tek gori u misto kod poste……
Grijane rucke su moran priznat veri gud zimi……
Na svome motoricu su ON skoro non stop tijekom zimskih mjeseci….
Da ih iman na Kralju to bi bilo top
Grijanje sica je opasno i to ne triba
Vizir na podizanje…..hm……ne vidin svrhu.samo drkanje pa jos jedna stvar koja moze crknit…..Na Kralju je kraci crni vizir…..Idealno……
Tempomat necu komentirat……
Ko je to stavia na motor/skuter triba ga obisit……
Reactions: exfreerider
a ima tu vec i ljudi u godinama, s problemima kicme, trnu im ruke..meni je neznam koliko puta proslo kroz glavu "e da mi je sad tempomat"..
Ma bizi ca
Kad si umoran ili te boli ruka na motoru onda stanes….. i odmoris malo……
Kakav tempomat po gradu
Ili na motoru do MA ili Knina,Vrgorca
Tempomat je za Australce i Americane…..sta rade na dan ravnice po 50 km…..i onda se zaborave pa santa maria……
Ja na novom motorinu imam tempomat i realno super stvar, pogotovo za kamere…
Naštelam ga po ogranicenju i kopam nos 🤣
ja kad se vozin magistralom, s autom naravno, obavezno na tempomat..puno sam opusteniji i bezbrizniji..ST-Omiš,nemas ti di vozit..kamere,policija,neda mi se uopce natezat s njima, a i naporno drzat gas na 50 km/h
Pa osobno, vizir je top stvar. Po gradu spustam, izvan grada dignem na pola a ako pada kisa dignem max i dosta pomogne. Neznam tko se moze uopce voziti sa kratkim sportskim vizirom Yamaha, to je bolesno, puse na sve strane ali svako zna za sebe...
Reactions: Nero
i plus sta je svaki sa kratkim vizirom ruzniji
Reactions: Dene
Moj vizir nije oni mali crni
Govorimo o Kralju i takorec OEM crnome viziru
Koji je manji od jedra sta je Kralj ima a opet dovoljno velik da stiti
Spuštam se jučer motorom na rivu i ispred mene novi t-max (bar mislim da je) sa tablicom ST-MATE :rolleyes: pa me zanima jel taj Mate ovdi na forumu i ima li veze sa krafnama kod Mate da nam napravi popust.
... jednom da se i ja slozim s tobom... radi toga sam i bio uzeo sx-a i ugradio samo grijane rucke.... a vizir postoji crni u istoj dimenziji kao originalni jer s onim malim crnim govnom duvaju promaje kroz vrata naroda.... :mrgreen:
^^kad par puta pogledan ne mogu se oteti dojmu da ovo i nije bilo baš namjerno ali ga je extra iskontrolira :p
