Nema podataka o snazi (slubenih). Evo ostali
Engine - 4-stroke, liquid-cooled, DOHC, 4-cylinder
Bore × stroke - 73.4 mm × 59 mm
Displacement - 999 cc
Compression Ratio - 12.5:1
Induction - Fuel injection 44 mm throttle bodies, two injectors per cylinder
Transmission - Six speed, constant mesh
Frame type - Twin-spar (aluminium alloy)
Rake/trail - 23.75 degrees / 96 mm
Suspension Front - Inverted telescopic, coil spring, spring pre-load fully adjustable, rebound and compression damping force fully adjustable
Suspension Rear - Link type, oil damped, coil spring, spring pre-load fully adjustable, rebound and compression damping force fully adjustable
Brakes Front - Radial mount, 4-piston calipers, 2 x 310 mm discs
Brake Rear - Two piston caliper, 220 mm disc
Tyres Front - 120/70 ZR17
Tyres Rear - 190/50 ZR17
Fuel tank - 18 L
Overall length - 2,030 mm
Overall width - 710 mm
Overall height - 1,130 mm
Wheelbase - 1,405 mm
Seat height - 810 mm
Dry weight - 166kg
Available - May (Approx.)
