alien
Nakon brojnih problema i opoziva nekih motora prošlih godina i ova godina je ista za Yamahu, jednog od najvećih proizvođača motocikala, a meni osobno najdražih dolby digital receivera.
Ono što je problem ovdje je da se ti opozivi događaju na najvećem tržištu, američkom, ali i australskom. Kada će ta viroza doći i na europsko tržište ne zna se ali obzirom da se kao i u svemu drugome prate, neće trebati puno čekati.
Nadam se da se nikome neće ništa desiti, a to valjda žele i u Yamahi obzirom na brojne opozive izazvane milijunski isplačenim odštetama za osobe koje su usljed defekta motora pretprljeli ozljede!
Više na http://www.pritzkerlaw.com/yamaha-motorcycle-recalls/
Motorcycle Recall - Yamaha
NHTSA Campaign ID: 08V180000
Component: Fuel System, Gasoline: Delivery: Fuel Pump
Manufacturer: Yamaha Motor CORP, USA
Recall Date: 04/17/2008
Potential Number of Units Affected: 9600
Manufactured:
Defect Summary:
Yamaha is recalling 9,600 model year 2006-2007 CP250 and model year 2005-2007 YP400 motorcycles. The engine could stall and be difficult to restart because the wire terminals in the fuel pump wire coupler have corroded. Water can enter from the main wire harness end and run through the harness to the fuel pump coupler.
Consequence Summary:
If the water remains in the coupler for an extended period of time, the terminals can become corroded, which can prevent the fuel pump from operating properly. If this corrosion affects fuel pump operation while the scooter is being ridden, there could be a crash resulting in injury or death.
Corrective Summary:
Dealers will install a sub-harness which is designed to allow any water between the wire harness and the fuel pump to drain out before it reaches the fuel pump. The dealer will also inspect the connectors. If either the main wire harness connector or the fuel pump connectors is already corroded, the corresponding assembly(ies) will also be replaced.
Yamaha Motorcycle - Model No. XJR 1300(EFI) - Throttle Position Sensor
Date: 18/02/2008
Supplier Name: Yamaha Motor Australia Pty Ltd
Product Make: Yamaha Motorcycle
Product Model: XJR 1300(EFI)
Target Number: 118
Model Years From: 2007
Consequences:
Campaign Number: M868
VIN Range: RP192-000001~RP192-000118
Serial Range:
Product Info:
Defect Details: The inner cover of the Throttle Position Sensor (TPS) may not have been sealed correctly to the TPS outer casing. If this is the case, the adhesive area may crack when the TPS screws are tensioned. If a crack is present, water may enter. If this happens, the TPS signal to the Engine Control Unit will be incorrect causing poor idle, engine stalling and hard re starting
Consumer action: Contact your nearest Yamaha Motorcycle dealer.
Manufactured:
Defect Summary:
Corrective Summary:
Date: 18/02/2008
Target Number: 118
Consequences:
Serial Range:
Product Info:
